Fuel Consumtion Display
  • Billman
    • 4129
    Hi, i have a Question, what is going on with this display, when other bigger injectors are used? Can we adjustit so it reads the correct amount of fuel? The same when raising fuel pressure!
    Go Holset or Go RS4
    There is *some* scope to adjust this with ECU programming. I think Mihnea has some tricks here, but I don't know the limit.
    Beyond that - we'd need to reverse engineer the trip computer in order to work out an alternative mechanism of recalibrating the fuel usage calculations.
    Paul
    • porkkis
      • 1994
      It's a 0-5V signal that can of course be tampered with.
