Fuel pressure - tested
  • dkw_dude
    • 555
    • Country: Norway
    Hi
    Measured the fuel pressure today (3B engine). It was 3 bar at idle (with approx 0,6 bar vacuum) and 3,5 bar with vacuum hose disconnected from the fuel pressure regulator.
    Both readings are 0,5 bar higher than spec, how much influence will this have on the running of the engine? Can't be good for the mixture??
    Ill try to correct this (will order new fuel pressure regulator tomorrow) and see how it goes..
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
