RS2 trim corrosion
  • alg
    • Apr 2004
    • 1160
    RS2 trim corrosion
    Just noted a small area at base of rear passenger window rear black metal trim (just above weather strip) is bubbling.
    On closer inspection this has been touched up before very well as you cannot notice it unless you get the light right.
    Has anyone done this before and know the best paint to use after sanding back. Ideally one of these rust treatment paints I guess.
    Or can you replace the trim ?
    Alastair
    RS2
  • iain1067
    • 984
    Trim replacement isprobably just as easier as sanding and painting,
    • alg
      • Apr 2004
      • 1160
      Agreed vagparts have them @ £23 each. So sorted although the pop rivets are a bit steep @ 24p each
      Alastair
      RS2
      • Martynf
        • 1885
        The rivets are galvanised steel though Alastair.... ;-)
        Mine is doing the same, will change it soon. Only the left hand side though? same here... I found this on the net, may help you:
        Martyn
        www.vagparts.com
        • alg
          • Apr 2004
          • 1160
          Cheers Martyn
          If they are galvanised then I say bargain................................hehheh
          Alastair
          RS2
