Leaking Coupe tailgate
  • dan_b
    • Sep 2003
    • 3670
    Hands up who has a leaking tailgate on their Coupe?
    Mine dribbles down in the left corner, leaking on to the left rear passenger seat.
    Annoying. Is there anything that can be done
  • porkkis
    • 1994
    I'm quite sure the rear washer jet sealing to tailgate is leaking. Replace it with newer design one (N-VIN = '92 on). The newer ones have a nut to keep it tight as the older has just a pair of clips.
    jet 895 955 957 A
    washer N 011 558 11
    nut "BM8" N 011 118 11
    rubber angle 893 955 665
    If this does not help, it's probably the hinge sealings, but if the water comes from the tailgate, not the roof then the jet.
