I seem to have developed a leak, and am getting water inside my boot on the right hand (driver's) side. (same side as the washer fluid inlet)
I'm quite sure the seal with the boot is fine, but I suspect that there is a dodgy seal between the top of my rear light cluster and the bodywork.
How do I get in to inspect?
I tried to remove the black plastic strip along the top of the boot, but even with all the screws out, it wasn't budging.
Will I need to remove the light cluster and inspect from there?
I'd appreciate it if someone (or several folks) could walk me through the steps on how to remove the cluster. Photos would be good too.
Thanks folks!!!
JohnB
Thanks folks!!!
JohnB
