Brake cooling ducts in place of foglights on S2 Bumper?
  • s2avant
    • 2426
    Your wish is my command Prepare to be shocked
    Duct NS 3D0 615 447 D Retails @ £8.73 + VAT
    Duct OS 3D0 615 448 D Retails @ £8.73 + VAT
    Back Plate NS 3D0 615 311 C Retails @ £18.57 + VAT
    Back Plate OS 3D0 615 312 C Retails @ £18.57 + VAT
    Bolts (x8) N 102 849 03 Retails @ £0.14 + VAT each
    Phaeton bits aren't that expensive really.
    Ben
    • rotoryboy
      • May 2004
      • 3281
      Ben
      WOW that's very sensible
      Mark
      Race Clio RS197
      S2 Coupe ABY (Green) - RIP
      S2 Coupe ABY (Blue) - Sold
        would we need the back plates since they will probably need adapting anyway?
        Ben can you get some of these in the name of brake cooling and see if it is possible
        ta
        • s2avant
          • 2426
          Oops, I was checking the prices and reading this thread at the same time and accidentally hit Shift-F10, followed by Shift-F1, then accidentally typed an order number and then pressed enter.
          Oh well. The back plates are on back order but the ducts will be with me Friday.
          Ben
          • PeterS
            • 423
            As to a brake duct that will fit into the S2 bumper, anyone have access to a set of BROKEN S2 fogs? They would make a good starting point for a fiberglass mold.....
            Peter S
            1990 ErsatzS2 - track toy
            1991 Coupe Quattro
            1991 Coupe Quattro
            1995 S6 Sedan
            1995 S6 Wagon
            • HPmuirt
              S2Forum April Fool
              • Apr 2005
              • 3014
              #21
              Hey, that's not a bad idea at all.
              As long as you dont want to mount the mini fogs, you could maybe use the actual fog light back, with the lense removed, and simply expand the bulb bolder area to accept a 2" hose
              There has to be a hitch with this plan...it sounds too simple Anyone front ended their S2 recently :mischeif:
              Cheers n
              Si
              Subtle mods here and there
              2011 A5 3.0 TDi - Lava Grey
              • HPmuirt
                S2Forum April Fool
                • Apr 2005
                • 3014
                #22
                Ben
                Sheesh, I hate it when that happens Maybe you could look up the remaining parts of the cruise control system that I need, whilst reading this forum
                Cheers n
                Si
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #23
                  Ben
                  SS
                  • Fat Audi 80
                    • 10547
                    I could draw some up on solidworks if anyone is interested and if anyone knows a plastic / injection moulding company I could see about getting some proper ones made for the S2?
                    The Perfectionist
                    • rotoryboy
                      • May 2004
                      • 3281
                      Sounds like a plan
                      Mark
                      Race Clio RS197
                      • Fat Audi 80
                        • 10547
                        Originally posted by rotoryboy
                        Sounds like a plan
                        Someone needs to send me an old foglight and I can model up a duct to fit exactly the same area. Then all we need to is make 'em!
                        By the way, there is no personal intrest in this for my car. Can you seem me modifying the front bumper? I just like a challenge
                        The Perfectionist
                          Originally posted by Greg_S
                          Just spotted this on RS246
                          Brake cooling ducts from the VW Phaeton, might be worth a try adapting them for the S2 with a different plate to fit onto the suspension
                          I gave these a try today, might work with a bit of adaption, the problem at the moment is that they will foul the ABS sensor in one position and possibly the lower ball joint in a slightly different position. When I have time I will have another go and see how i get on.
                          With my 330mm discs it doesnt give that much air to the middle of the disk, will see how I get on next time
                          • Alistair C
                            • 693
                            #28
                            and if anyone knows a plastic / injection moulding company.....
                            you do know that making functioning tooling for injection moulding is a very expensive business...... £1-£2K for a very simple & small object...... and then there is setting up, proving and purging...... Not wanting to put a downer on your plans, but I can't see it happening for the batch size you'd be talking about.
                            GRP or carbon - now that'd be a different matter. CNC a mould?
                            • Fat Audi 80
                              • 10547
                              Hey - I was just going to draw them!
                              Someone else has to make 'em!
                              The Perfectionist
                              • Albert
                                • 1500
                                • Country: Poland
                                #30
                                And how did it go ??? I want to do the same brake ducts for my brakes.
                                AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
