RS2 mirror wiring
  • s2avant95M
    • 1217
    • Home: England Current: United States
    RS2 mirror wiring
    Does anyone know what wires in the RS2 mirror correspond to which wires in the S2 Avant loom. There are a couple of threads that i have found which appear to list them but they are appear to be wrong.
    Also there are 2 brown wires inside the mirror, what are these for?
    Cheers.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
  • pastures16
    • 2058
    where did you get them from tim
    94 s2 avant
    aoc member 1116
    • Flexx
      • May 2004
      • 248
      I have this kinda wireness for sale.
      They are from RS2 OEM.
      Flexx
      • jubjub
        • Nov 2003
        • 1239
        I thought the brown ones are for the heated mirrror
        • s2avant95M
          • 1217
          Yes, I thought that, are some heated and some not? there is nothing to plug them into on my mirrors.
          @Flexx Too late for the loom, ive made electrical plugs for each wire, just need to know which one connects to which.
          Tim
          • pastures16
            • 2058
            if you get bored of them tim you know who to pm
            94 s2 avant
            aoc member 1116
            • jubjub
              • Nov 2003
              • 1239
              [QUOTE=s2avant95M]Yes, I thought that, are some heated and some not? there is nothing to plug them into on my mirrors.
              QUOTE]
              Thought all teradropswere heated ? On the back of the mirror there should be 2 tiny bullet clips that are attached to the mirror ( at the widest end so to speak) As it happened, one had sheared off on mine. Spent a good bit of time trying to solder a new clip on, only to evetually sus that it is impossible to solder. Ended up sticking it with a metallic glue.........
              it works fine and the current passes through it now, but for some reason the whole mirror has stopped working now. The motor definately works though.....
              • martinjs
                • 3205
                I wired mine up as in peterp's post in this thread Tim, worked ok.
                • rs2coupe
                  • Oct 2004
                  • 1782
                  • Home: Trinidad and Tobago Current: United States
                  Say.. what if one wanted to go back to standard s2 mirrors after cutting to fit rs2 aero mirrors? Is it possible to do this or is this a permanent procedure?
                  Curioust
                  Cheers mis amigos,
                  _Anton
                  • S2 Ant
                    • 3682
                    Anything can be undone, would just need to chop and change it back again and be handy with a soldering iron by the sounds of it.
                    Ant
                    2011 Kawasaki Z1000
