can not open my drivers door
  • rs2paul
    • Jul 2005
    • 58
    I shut the drivers door on my RS2 & it will not open??
    Have tryed both inside & outside lever, but will not un-latch.
    When using inside lever, it will set the central locking??
    Any ideas??
  • WabTheKing
    • May 2004
    • 2567
    pull the iside latch, there is a small posi head srew
    undo this and remove (without dropping)
    slide the whole of the latch casing towards the front and pull out
    unclip the hook off the latch (do not loose the clip)
    pull the hook whilst holding the outer of the cable
    door should open
    if not - erm - you may have a problem
    • mcandmar
      • Apr 2004
      • 5118
      Try locking the door with the key, then unlock and see what happens.
      I noticed on mine if somebody pulls the passenger door handle up while the central locking is unlocking the door it stops working, inside and outside handle do nothing until i lock and unlock that door with the key to reset it.
      If not same as above
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • A80Avant
        • 10873
        • Country: Greece
        if none of the above works,and it is not a central locking problem,then you should unhook the door panel to reach the hook of the inside latch.It may have been unhooked and lost its connection to the inside latch.
        However if the door does not open from the outside either,then you should look for a new lock probably...
        cheers
        vasilis
        • Sidspud
          • 1223
          • Home: Scotland Current: United Nations
          cheers
          vasilis
          You can't unhook the door card because there's a screw at the side which is impossible to get to without opening the door.
          ex '93 Avant owner
