Strange thing I have noticed
  • Azman
    • Sep 2005
    • 3205
    I hope I have put this in the correct part of the forum but I didn't know which to go for.
    A friend of mine noticed to day that on level ground the rear drivers side of the car seem to be sitting a bit lower than the right. This was clarified by measuring the gap between the tyres and the arch. there is a good 20mm difference.
    Any clues as to what would cause this as this wheel is the one that is sitting a bit further forward than the other side too. (see my other thread)
    Aaron
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
    have you checked the chassis isnt bent?
    • Ski
      • 2591
      maybe u have 20mm extra tyre tred
      but on a serious note, maybe ur shocks are gone? does it feel "softer" on that side?
      ABY Coupe
      • BRY
        • 3755
        Check your springs are located properly, and that one hasn't snapped.
        I snapped a spring on my Mk1 Golf and it it dropped by about the same on one side.
        • Azman
          • Sep 2005
          • 3205
          @Greg - surely if the chasis was bent there would be the tel tale signs in the bodywork. Gaps being bigger on one side to the other, a slight ripple in the roof of the car?
          @SKi - I know I do need to replace the shock although they have just passed an MOT (which I know means nothing)
          @ Bry - the whole of the bottom of the car is supposed to be off this weekend for new bits so I will have a look then
          Cheers guys
          Dark Grey Avant
          RS2 FARB
          • Keeper of The Kitten
            • Dec 2003
            • 2317
            More likely that one spring is a little softer than the other, just a little more "tired" - it happens. Dampers are not supposed to support the weight of the car, just to dampen the sprung movement. The springs take the load, so a soft spring would be top of my list.
            __MDC__
            Martin Cutting
            • Azman
              • Sep 2005
              • 3205
              Hopefully a set of springs could cure this then?
              Dark Grey Avant
              RS2 FARB
