The movement of my sunroof has gone quite stiff and I'm thinking I need to give the mechanism a bit of lube to free it off. The motor seems to be OK as it works fine on the bits where the movement is still free.
Any suggestions for a suitable lube for the runners and cables on my sunroof. Are WD40 or silicon lubricant a good idea or do I need some special expensive dealer only sunroof grease?
David
David
