Sunroof Seal Change
This is a sticky topic.
  • nigelm
    • 150
    Sunroof Seal Change
    Am going to tackle this seemingly simple job.
    Anyone have any do's or don'ts to share?
    It's the solid metal sliding sunroof not the glass one.
    Thanks
    nigelm
    ABY coupe
  • geryS2
    • May 2006
    • 814
    • Home: Belgium Current: Portugal
    Good idea, it s on my todo list !!
    Don't forget to post some pics, good job for the long week-end
    S2 's and oldtimers
    • s2driveruk
      • 12696
      I think from memory - was a long while back that you do the following:
      1) Shut the roof
      2) Place you hands on the roof lining towards the front section and push up slighty and slide it back towards the rear of the car
      3) You should feel and hear a clunk as the two push on clips release at the front of the sunroof - the headliner and sunroof should now be separated.
      4) You can then swixel the liner through 90 degrees and remove it
      5) open the roof - up not back obviously and Locate the 4 x star head screws which hold the roof to the sliders and remove them
      6) roof will lift off the car now
      7) pull the old seal off
      8) Slip the new one on - i used a small amount of glue to make a firm seal on the two ends of the seal once on.
      9) refit the roof...might need another set of eyes to check roof is level while you tighten up the screws
      10) ensure the roof is then up and slot the liner back in - making sure to locate the front portion into the guides
      11) From memory pull the liner up until it butts up against the pegs on the roof itself
      12) get out the car and lift the back flap up and position the rear pins into the guides so that it lifts the liner when the roof goes up
      13) once the rears are located i think u just close the roof and lift the front end of the liner slightly to get a grip and force fwd so it clicks over the pegs again. Only thing i can't remember is if the rear water channel gets in the way when doing the rear pins but you'll work it out I'm sure.
      hope that helps,
      David
      1992 3b S2 Coupe
      • SteveH
        • 4460
        Nice one David
        I have to do this job and I've been putting it off, I'll give it a go now. any idea on the cost of the rubber seal?
        Cheers...
        91 Modded 3B
        14 A6 Avant Black Edition
        • s2driveruk
          • 12696
          Can't remember but fairly cheap i think...
          1992 3b S2 Coupe
          • nigelm
            • 150
            sunroof seal change
            Thanks David - very clear instructions.
            nigelm ABY coupe
            • panzerwagen
              • 900
              Nigelm BEWARE! The push clips break easier that rotten eggs!!!
              For sake of mind get new ones before you do this job! I have done what you endeavor and the broken clips held up the completion of it. To make matters worse, some dealers have those clips listed as NLA! They are out there, just get them.
              I can't stress this enough!
              • nigelm
                • 150
                Push clips
                Perhaps I'll get some push clips then.
                Thanks Panzerwagon
                nigelm
                • nigelm
                  • 150
                  Push clips again
                  Could anyone confirm the identity of the push clips? Perhaps on the attached pictures.
                  (See next post also)
                  Thanks in advance.
                  nigelm
                  • nigelm
                    • 150
                    push clips
                    here's the second
                    nigelm
                    • panzerwagen
                      • 900
                      On second pix.....
                      • nigelm
                        • 150
                        push clips
                        Thanks PW,
                        No. 6 looks suspiciously like the seal itself though in the second pic?
                        You don't mean no. 8 do you?
                        nigelm
                        • panzerwagen
                          • 900
                          Sorry nigel....#2 it is.
                          Good luck in the change.
                          • panzerwagen
                            • 900
                            So sorry AGAIN Nigel!!!!
                            It is #8 sheeesh!!! Germany - Argentina game got me amped up!!!!
                            • madS2
                              • Nov 2005
                              • 552
                              does any1 have part numbers 4 these clips,im in desperate need!
                              Looking for an S2 ABY
