Not a big problem but I have a small patch of rust under the rear RS2 badge on the tailgate.
I guess a previous attempt at the badge is the cause. I had it repainted a couple of years back but (as you would expect) its back with a bubble or two on the outer side and a small area of rust on the inner aspect.
Are any of the rust treatments useful or should I just get it repainted again ?
Clearly the galvanisation has been damaged but is there a longterm solution ?
