dodgy boot! hard to open!
  • Welleh
    • Aug 2005
    • 106
    hi!
    got a little problem thats really annoying me! what happens is, is i push my boot lock to open it, but it wont open it unless i push down on the spoiler!
    anyone know how i can fix it? it's one of those annoying little things that always catches you out in a rush!
    cheers
    Steveo
  • Markarina
    • Mar 2006
    • 511
    • Home: United Kingdom Current: Switzerland
    I'd be interested to know as well as I have exactly the same issue
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      I thought that was normal. A few people I have seen do the same.
      SS
      • Welleh
        • Aug 2005
        • 106
        at first it was ok though! don't know what made it go like it has but i used to just press the button and up it went after a little shift upwards!
          The stop for the boot probably needs adjusting since it is pressing against the catch stopping the spring releasing it
          • Graham
            • 1622
            Peel the carpet back in the boot, and you will see the rod linking the lock to the catch, at one end of the rod it is threaded and goes into a plastic top hat configuration, IIRC you push in the center part of the top hat and slide the rod in a MM or so, then re pop the holding mechanism into place and try it again, they stretch and wear with age and the stroke on the worn part to long to actuate the catch. This will cure it, i have exactly the same problem on my last coupe and 2 Golfs. Also if the top hat arrangement looks brittle/fragile, another way is to unhook the other end of the rod and screw it into the top hat, this has the same effect as above by shortening the rod and removing the slack.
