As you can see the shield has been compromised from years of exposure to heat, water, stones, snow and other elements. The end result is that gunk ahs been lodged inside of it causing serious damage to the fuel lines. Mostly pinholes allowing fuel too weep out.
As you can observe, the leaking fuel in time has caused even more damage to the lining of the shield. This is a hazard that needs attention. Look to your shields boys!
