Someone out there, or no doubt several will know which porsche mirrors fit straight on the avant apparently without any mods. Replies please part no s etc. Ta
RS2/Porsche mirrors
Crap - as in small, they don't offer as much rearward vision as the standard box shaped mirrors.
I find that with a bit of time to get the adjustment right, they are ok - but they will never offer the same vision as the standard mirror.
I'll be keeping the RS2 mirrors though, I get on with them and IMHO they do look better when you compare two cars with both types side-by-side.
__MDC__Martin Cutting
They do look nice, even more so on coupes imoa BUT i have used a set on another cart and found that i was blind. But as said you will get use to themLast edited by terrybullwon; 4 December 2006, 12:32.Chef
I bought a set of porsche mirrors and I need a "screw" or fitting for the mirrors, like a plate or something, does anyone know what I mean?? (this is not RS2 mirrors) , so I need a porsche part #.2004 9-5 aero
2009 Subaru Legacy Diesel
1994 Toyota Supra Eurospec 6-spd LHD
3-4 Audis in parts
Don't think this is off topic, but which Porsche/RS2 mirrors will fit the S2 ABY Coupe please?Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
Present: S4 B8 avant, MRC Stage 2
Originally posted by CliveHDon't think this is off topic, but which Porsche/RS2 mirrors will fit the S2 ABY Coupe please?
They are a bolt on for advants from the RS2 but coupes need a lecky workLast edited by terrybullwon; 12 January 2007, 10:41.Chef
Originally posted by terrybullwonThey are a bolt on for advants from the RS2 but coupes need a little door and base work
being a bit "mechanically challenged", what does that involve? is it an easy job?
(or should I just do a search and stop asking silly questions...? )Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
http://www.s2forum.com/forum/showthr...ght=rs2+mirror
Only neeed to chop the door if they come from a porker
This is something i will be doing in the summer when i am having the rear bumper sprayed and maybe a front rs2 one if i can soruce itChef
You use a dremel to cut a bit in the door , the hole for the mirror is too small for the rs2 mirror base.
Can someone PLEASE help me with the 2 screws I need for the porsche mirrors2004 9-5 aero
3-4 Audis in parts
The porsche mirrors are crap UNLESS you have the convex mirror glasses in them. Then they are the best mirrors out there. Much better then the stock S2 mirrors.
