Audi 80 Bonnet and Doors for an RS2 ???
  • Audi 80 Bonnet and Doors for an RS2 ???
    As per title, wanted to check if ordinary Audi 80 doors will work on an RS2 that is having a glass our respray ?
    I'm thinking in particular of the external trims on the doors, and the metal shape on the two respective types of doors where the rim mounts.
    Pretty sure the bonnet is interchangeable ?
    But obviously want to double-check in advance of the car being stripped down.
    Thanks for any help / experiences.
    The bonnet is the same, the doors are interchangeable if they have trim strips, not all 80s did. Even though ETKA doesn't show different part numbers, the rear doors are different in that they have an extra rubber seal along the outside edge, the channel is spot welded on so it's not possible to retrofit.
    92 Audi 80 Quattro => RS2 Saloon!
    98 TVR Cerbera 4.5
    63 Austin Mini Super Deluxe (turbocharged)
    69 Austin Mini Cooper
    71 MGB GT
    75 Daimler Vanden Plas 4.2L
    04 Kawasaki GPX250
    96 Subaru Legacy GT-B
      Thanks for the quick reply.
      Should be ok as it is just the rhd passenger door that would be better if it was replaced apart from the bonnet.
      Thanks again.
        Yep i concurs with 80Quattro, the RS2 has an extra rubber trim strip which is on the door rather like the C4 A6/S6 David. My Audi 90 20v had these rear doors with extra rubber strip but the later B4's didn't only the RS2.
          Some random B4s has that rubber strip. I know two S2 avants that had it and have seen various regular B4 80s with it.
            Does anyone have a picture of that rubber strip?
            1989 Audi 80 Quattro
              http://www.getpalmd.com/2016/11/audi-rs2-avant-porsche/
