I've searched for a how-to guide or sticky but I can't find one.
I have two issues to contend with, one is the dreaded spinning cage nut of doom. How do I remove the 13mm bolt when this happens? Mole grips just keep slipping off for me. Any tips?
The other thing is I think there must be a hidden torx screw or two about half way up the trailing edge of the wing but I can seem to see them, I can see there is a small horizontal bar riveted to the wing, so I assume the screws must located on the A pillar when at the other end of this bar. Does that sound right?
Any guidance would be great.
edit: the Bentley bible doesn't have it which is surprising.
