s2 coupe door protective rubber strips
  • s2 coupe door protective rubber strips
    Hi
    Please can someone tell me what the rubber door strips on the bottom are held on with?
    I think its no 23 on the parts diagram but not sure what no 24 is and if i need it?
    Thanks in advance
    Little greenish plastic clips about 2.5cm by1cm
      cool, thanks
        I've got quite a few new ones of these, they don't usually break when you remove the strips. Can chuck a few in with the Tradition parts if you don't need a full set?
          Thanks for the offer but already got some sorted now Do the strips just slide off?
            Yes should slide off quite easy dont use too much force
