HELP!!!!!! Need mounting info bad!!!
  • panzerwagen
    • 900
    I need the specs on where the holes are located on the rear of the S2 Coupe to drill mounting holes for rear bumper mount brackets! Anybody please!!!
  • Paulgo
    • Jan 2005
    • 498
    Hi mate
    I havnt taken my bumper off yet to measure on the car - but I can give you some measurements from the bumper itself if this helps, from which you shuld be able to get the position on the car.
    From the centre of the bumper to the centre of the securing bolt on the bracket its 410mm. The bolts are 50mm apart at from the centres. The top bolt is 90mm from the outside lip of the bumper to the centre of the bolt.
    Hope this give you what you need to get it fitted - but If you need any more measurements or pics of the bracket or the back of the bumper etc fire away
    HTH's!
    cheers
    Paul
    Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
    Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
