As you are aware the standard front bumper washer jet has been unavailable now for some time.
I have been working on a solution which I think may have been covered before, but have shared the process here with photo’s for others.
Start off by ordering Land Rover Range Rover Sport Jets part number LR015359.
They come with a section of rubber hose attached.
Firstly remove this hose.
Then using a sander or a file reduce the edges of the jet until it fits snuggly into the jet housing on your bumper.
Keep trying it upside down for now to check for fitment.
From this use a sander or a file and remove the extra non required plastic as shown in the next photo.
Keep sanding or filing a taper onto the end of the jet as shown until the jet can be firmly pushed into position.
Once fully fitted it will look as follows.
