Audi S2 3B 1990 Bumper Need Advice
  • smh
    • Jul 2008
    • 70
    https://www.ebay.co.uk/itm/262236680253?ul_noapp=true
    Here is a link of a brand new bumper which looks exactly the one I need on eBay, has anyone purchased this replica before? Do you have to make your own holes or will any adjustments be needed? Need to clarify if this bumper is good quality and can be fit on without any problems.
    Thanks.
  • John.
    • 2615
    You realise this is just the "shell" and it will need the mounting points cut from your old bumper and bonded to this one ??
    • M2ki
      • Aug 2015
      • 547
      Don't buy this fiber glass piece of ****. And it is located in Latvia, so expensive shipping too probably.
      You can get original bumper with grills for 250gbp. If you do not need the grills, maybe even cheaper.
      Check cabrio and coupe facebook pages, lots of v6 cabrios are being parted out.
      1989 Audi 80 Quattro
      • Lefrog
        • Feb 2017
        • 194
        I be got a used front , it's the headlight washer type has a little bit of damage but easily made good ,
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          I find these fiberglass copies reasonable quality. Best way to make mountings is to source good used inner plastic brace from damaged B4/S2 bumper: needs to be cut out. These are extra efforts to be considered.
          Personally I ended up buying new OEM bumper: costed me about 450 GBP without grills.
          • Antsa
            • Nov 2016
            • 611
            I bought one like that and it is a hell of a job to cut all holes, mounting points and make your own brackets. If I were to do it again I would just search a used one.
            • 4WDrifter
              • Nov 2012
              • 1251
              Here’s one
              https://www.ebay.co.uk/itm/AUDI-80-B...EAAOSwMoZc0W~e
              NCTS
              and one here on forum
              1996 S2 ABY Coupe silver
              2003 S3 8L dolphin grey
              2014 RS4 B8 prism silver
              • steve briance
                • Aug 2014
                • 1455
                The link to the bumper on ebay is not an s2 bumper, if only it was for £60!
                • 4WDrifter
                  • Nov 2012
                  • 1251
                  Well spotted Steve. 1000 apologies!
