s2 windscreen rubber
  • s2 windscreen rubber
    does anyone know where i can get a new windscreen rubber or part number please
    93 ABY S2
    Hi do you need the top or bottom one?
      Have a crack in screen found someone that can supply new screen and fit.. they said would be handy if i could get a new rubber..
      93 ABY S2
        It would be handy if that person explained what they meant... The screens are glued in rather than held in with a windscreen 'rubber' seal. Sometimes the top and bottom trims can be re used, usually they can't.
        Find a new windscreen person - the one i used had a range of trims in his van and they were 95% right compared to the hard to find originals. Fitted ok.
          Lol.. it hasn't the original screen it looks like whoever fitted it cracked it when fitting.. it's no big deal crack is right at bottom corner but would change it if possible ?
          93 ABY S2
            When I collected my windscreen from Ricky Evans they suggested these trims. Not got round to buying them yet as been busy dropping the sub frames. Might be worth a look?
              thanks Bud .. the link takes you to the web page but says not found or removed.. clicked on Audi 80 etc but nothing
              93 ABY S2
