Porsche 993 mirrors, changing the base foot
  • coupegt
    • Jan 2005
    • 218
    • Country: Denmark
    How do you change the foot on the 993 mirrors so they will fit the S2.
    Can you use the foot of the original B4 mirror or is a new one required, and if so, where do you get it.
    There was a thread by Prosty and Quattro_king detailing how to fit the mirrors without changing the base.
    • coupegt
      • Jan 2005
      • 218
      • Country: Denmark
      sounds great, will try a search, thanks
      Other answers welcome
      • coupegt
        • Jan 2005
        • 218
        • Country: Denmark
        Hmm, so basically you have to cut a little of the sheet metal of the door?
        Not to happy about that, but that´s the only solution i can find?
        I assume, that this also will make it impossible to go back to the old mirror type (if you for some odd reason would want that)
        • panzerwagen
          • 900
          RS2 mirror base....
          You could also purchase the proper base for the mirror . The following link as the PN#.....
          http://www.s2power.com/porsche%20spiegels%20en.htm:)
          • panzerwagen
            • 900
            Sorry about that bad link....
            Here's the info on what it's called, PN#, price and how many you need.
            adapter (10) 8A0 858 551 6.53 2
            • Jas11n
              • 5067
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • coupegt
                • Jan 2005
                • 218
                • Country: Denmark
                Let me get this straight.
                If you buy the adaptor 8A0 858 551 the 993 mirrors is a straight fit to the coupe???
                Or du you still need to dremel the door?
                BTW, a friend of mine with a 90 2.3 20v (B3) want´s the mirrrors also.
                Is the mod procedure the same for this car?
                • aronmatic2
                  • 2129
                  • Country: Hungary
                  you have to dremmel the door and the 993 mirror foot too.
                  here is a good link:
                  Real carbon parts for S2 and RS2. Check Carbondesign on facebook
                  • coupegt
                    • Jan 2005
                    • 218
                    • Country: Denmark
                    Thanks.
                    Looks like i got 2 sets (4 mirrors) on the way from germany now, so defenitly need to get them on the car
                    • aronmatic2
                      • 2129
                      • Country: Hungary
                      i fitted to my car. it was couple hours.
                      • coupegt
                        • Jan 2005
                        • 218
                        • Country: Denmark
                        http://www.rezacze.pl/warsztat/lus/lus.html
                        Using this guide, how do you fix the mirror to the door?
                        This is one pic with a small hook or something attached to the screw withc goes through the mirror, but it´s hard to see how it´s made.
                        Is it at custom brakcet? Any further pics perhaps?
                        • aronmatic2
                          • 2129
                          • Country: Hungary
                          you have to go to local porsche dealer you need 2 screws, 2 mirror holder, 2 rubber seal
                          for 1994 porsche 911 carrera.
                          its cost 25euro.
                          • coupegt
                            • Jan 2005
                            • 218
                            • Country: Denmark
                            Oki, got the original Porsche screws and rubber seals allready
                            So just missing the mirror holder then, thanks.
                            • archiboy24
                              • Sep 2003
                              • 286
                              Does anyone know if there is a part number for this little 'hook' part?
                              Ben
                              Calgary, Alberta
                              Canada
                              1991 CQ e//S2 w/ RS2 spec 3B 20vt
                              Panther Black Metallic
                              www.moda-architecture.ca
