I just changed out the door seals on my Coupe after being unable to fix the wind noise and noticing that they looked degraded. After swapping them out I've noticed it is a lot harder to shut the doors with the windows rolled up. Is that just the seals still being very stiff and not being settled in to the windows yet? I thought maybe the previous owner might have adjusted the windows to clamp to tight to get the old seals to work. It looks that way since the top part of the glass is the first to hit the seal. Would realigning both windows solve this?
Also, I noticed that on ETKA they list a different seal for the earlier Coupes. I'm not sure that mine were this same part number. Would this have anything to do with fitting issue? It doesn't seem like theres much they could change that would affect it much.
Any thoughts appreciated. Thanks.
