leccy sunroof
  • eamo
    • Apr 2007
    • 41
    leccy sunroof
    my leccy sunroof has suddenly stopped working - it wont tilt or slide
    is there a relay/fuse i need to check and if so where is it located - engine bay or under dash?
    i have a 20v quattro coupe
    thanks
    Quattro Man!
  • Acidburn
    • 13459
    If you've got a tester you could check see if there is power getting to it?
    If you find out if that there is power there or not then you will know what needs doing, if you find the motor is knackered I have a spare motor/cover/switch
    • S-Express
      • Nov 2006
      • 1133
      try checking the wiring loom going from your car body to the doors - A brokem wire there can actually stop the roof from working.
