fuel flap locked
  • ujimaflip
    • Nov 2006
    • 121
    • Home: United Kingdom Current: Belgium
    fuel flap locked
    Hi Guys,
    The central locking on my S2 has never worked... however much to my dismay my fuel flap has just locked itself...
    I found this thread already - http://www.s2forum.com/forum/showthr...fuel+cap+stuck but there is no detail on how the flap was released (without doing damage). I'm getting low on fuel - any advice?
    There's a manual release on the inside drivers side behind the trim IIRC
    • Jas11n
      • 5067
      Yup, Jamo is spot on.
      It's described in your owners handbook. A quick scan of it in case you don't have one.
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • ujimaflip
        • Nov 2006
        • 121
        Doh... RTFM as many may say....
        Cheers - maybe I need those reading lessons after all.....
        • Corey
          Banned
          • Sep 2003
          • 2793
          Or just open your passenger door, which does control the central locking (this fix is only on your car though Dan, there is an issue with the accuator in your drivers door)
          Corey
          01636 822288
          • ujimaflip
            • Nov 2006
            • 121
            actually this seems to have been confounded by the pushchair I'd rammed in the boot..... Yes the kids are allowed in now the brakes are fitted (I'll post some pics of the brakes later) - stops very nicely now thanks Corey
            • Markarina
              • Mar 2006
              • 511
              • Home: United Kingdom Current: Switzerland
              had the same problem on my car when the alarm was playing up, found everything worked when you used the key in the passenger door
