Hi guys,just in abit of a muddle with these avant b+c pillars,Does anyone know if these are the same size all way round?
Avant trims
Originally posted by madS2 View PostHi guys,just in abit of a muddle with these avant b+c pillars,Does anyone know if these are the same size all way round?
The B pillars is easy to mount, but the C pillar you have to use a nailgun or what you call it over there (important, use BIG ENOUGH nails, so that they dont loosen, and be careful so you dont seperate the epoxy from the carbon when nailing it to the pillar)
Anders - S2 Avant Clubsport - 8pots or die!
Looking for an S2 ABY
That looks like the C pillars yes.
If they got two holes in bottom of them (or in top, by which way you're holding them) they are the B pillar.
The B pillars is a bit thicker than the C pillar, and the B is also a little more straight up and not "twisted angle" like the C. Difficult when you dont have both to compare, but out from the pic it looks like the C pillars.
If i also renember correctly, the C pillars have a kind of "clips" on the one side to get them to sit tight and firmly. Check it, cause the B pillars dont have that.
