Trim removal?
  • AndyP
    • 6049
    Trim removal?
    Can anybody tell me how this piece of trim is held on? Is it bolted from the inside or clipped on the outside? Same for the longer one on the door too.
  • andyg plym
    • Nov 2006
    • 4646
    bolted from inside 3 iirc
      Sure ?
      I thought those were a weird slidey clip - never done one... Sorry - just assumed.
      • rs2coupe
        • Oct 2004
        • 1782
        • Home: Trinidad and Tobago Current: United States
        The lower rubbers are sliding. The door guards are cliped in with plastic barbs that need to be pressed and squeezed out from the inside.
        Cheers mis amigos,
        _Anton
          as andy says take off the inner 3/4 trim and undo the three 10mm nuts, pulls straight off
          door is the same but a PITA as you need to remove the window mech to get to the nuts
          • AndyP
            • 6049
            • spink
              • 4382
              did the one on my s2 a few weeks back and i could get to all the nuts with 'just' the door trim removed.Bit of overkill if you ask me but i suppose it stops people nicking them.
              • k.alle
                • Feb 2008
                • 801
                Yeah I second that, stripped the car for the respray a couple of weeks ago, all of that trim stuff on the waist of the car was bolted on.
                Be careful with the ones on the front wings, they are NLA.
                Broke my left one, NLA, phoned the scrappers and they broke theirs too not realizing it is bolted on
                Bit of glue sorted it though
                Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
                http://www.garaget.org/?car=52877
                  you're right actually... for some reason i forgot the window moved
                  I'll definately be keeping the wing trims off my old rust ones when they come off then
                  • Al Wyn
                    • Nov 2006
                    • 3746
                    What about on an avant guys? the trim is the same colour coded piece (but thinner) and there arent any bolts inside the door so do they slide or are they bonded
                    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                    • pixsaudisex2
                      • Sep 2004
                      • 3110
                      Double sided stickey tape on the s2 avants. as well as the rs2 ones.
                      • Al Wyn
                        • Nov 2006
                        • 3746
                        Cheers bud and correct... as i found out earlier today
