Plastic welding
  • Acidburn
    • 13459
    Plastic welding
    http://cgi.ebay.co.uk/Plastic-weldin...d=p3286.c0.m14
    I've been looking into getting the equipment so that I can repair two bumpers i've got and was looking on ebay at some, this one made me laugh as it just looks like a soldering iron with some plastic rods etc.
    Anyone had any experience with plastic welding, i've got two different bumpers to repair with two different problems
    One has a split at the top of it which needs just joining back together its all still there fine etc, I was tempted to use something like arldite/hot glue gun just to join it back together before it gets smoothed then sprayed.
    The other is missing a corner on it so would need to be joined back together top/bottom.
  • quattronutter
    • Jan 2005
    • 690
    you can use a soldering iron or mini blow torch and rods to weld plastic you need to fuse the plastic together,glue will just split apart
    • Acidburn
      • 13459
      Cool i'll have a look into that as one of the bumpers (2door escort one) is just that hard to find so i'll give that a go and try get hold of some rods off the bay.
      Then just checking with my old boss (injection moulding manager) to confirm what material the bumpers made out of, been a while since I did injection moulding.
      • Nuvo
        • Nov 2003
        • 3825
        Its likely to be made from GRP (glass reinforced plastic)
        • quattronutter
          • Jan 2005
          • 690
          i use bits of old bumpers cut into strips as welding material
          • Acidburn
            • 13459
            Cool, i'll have a look tommorow when i'm off work as its been about 6 ish years since I trained to do injection moulding. I've got to take the last couple of bits of tape off and see exactly how bad it is.
            • Acidburn
              • 13459
              Cheers for that as I will be removing the front bumper from the car so could cut that up.
              Take it that you just get the two bits that have to be joined, joined together then heat up the plastic and drip or push it onto what needs joining?
              • quattronutter
                • Jan 2005
                • 690
                yes pretty much,the plastic doesnt stay molten for long,it will need sanding down carefully and filling with plastic filler after,repairing plastic takes a bit of practise
                • Acidburn
                  • 13459
                  Cool might give that a go this weekend as I got 4 days to practise on it. Just have to do it on the car so it holds together then I can remove it and fill over it for extra strength before it gets sprayed.
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    I found this...
                    Carlos.
