RS2 front bumper removal
  • Golfboy666GTI
    • Sep 2008
    • 571
    • Country: New Zealand
    Is removing an RS2's front bumper the same as a S2 bumper as featured here:
    1980 VW Golf GTI Track Car
    1995 Audi RS2
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    yes
    but in both cases,removing the undertray is not a necessity.I have always removed the bumper without touching the undertray.There may be screws on the RS2 undertray that attach to the bumper,which need to be undone,but thats it.The rest of the procedure is pretty straight forward.
    Remove corner lights and fogs,undo the bolts on the arches(2 on each side usually) then undo the 4 bolts(2 on each side) that are found on the mounts of the bumper,just behind the area where the fogs sit.The bumper mounts are bolted on the chassis itself.Also remember that the RS2 bumper has the hose connected for the headlamp washers so as you retract,make sure you dont go far,especially on the right side,as the hose will extent dangerously
    • Sonic
      • Jul 2006
      • 5514
      yep
      S2Forum.com Administrator
