hiya i am after some advice, afew months ago i had a water leak in the drivers footwell, i replaced the rivets and sealed the trim round the door and sealed up the grommet in the bulkhead where the bonnet cable goes through and it's been ok since. however after been stood for a week with and a fair bit of rain coming down it's full again. any ideas anybody i wondered if its worth replacing the door seal.
footwell full of water again !!!!!!!!!!
could be the sunroof drainage ducts are blocked, not un-common on these cars, door seals are not cheap and second hnd ones as i found out the hard way are often worse seals than the originals.
Ant91' Coupe quattro 20v - project
KW V2s and other goodies
now gone
03' BMW 330CI - Sold
08' A5 Coupe 3.0l tdi quattro - Sold
57' BMW 525d M Sport Touring -
not sure i'm afraid, there'll be something on here if you search i'm sure, of the top of my head i think its just a pipe so need to put a wire down it, best wait to hear it off someone who's done it before though. pitty about the price of the seals, i'll need to shell out next year, fed up of howling wind noise!
now gone
57' BMW 525d M Sport TouringComment
it can also be the hose for the AC drain, weas on mine, it is located on your drivers side against the middle console so far ahed you can get ( not so good description, ask if you want a better one)
One thing i've learned we are way behind the Scandinavians!Comment
to unblock/clean the above i`ve used some mig wellding wire pushed it from top to bottom tied abit of rag to bottom end and pulled it back through it comes out under lower hinge one either sidenot sure i'm afraid, there'll be something on here if you search i'm sure, of the top of my head i think its just a pipe so need to put a wire down it, best wait to hear it off someone who's done it before though. pitty about the price of the seals, i'll need to shell out next year, fed up of howling wind noise!
AntABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
could also be:
sunroof seal
broken or missing sunroof drip tray
scuttle trim misaligned (sits just below the front windscreen, if the rubber flab off the bottom of the glass is not sat right, water can get in behind it
same as above but water gets in through the heater unit
aerial base - if you are parked on a forward slant, water will run the length of the car and pour down (worth a good feel of the whole roof lining so see if its saturated...sometimes doesn't look it until toughed then water pours off it
BTDT already this year.
HTH
Davidsigpic
1992 3b S2 CoupeComment
