I have an Emerald green one going spare, I think there's a little rust around the bumper mounting holes, just about any second hand wing will have this. I know its dent and scratch free. I can check the condition later this evening for you. PM me if you want
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
Hi David.....Yep, thanks for your concern and well done for remembering!
I turns out that I actually had 2 seperate problems.
As you know i narrowed it down to a sensor problem. Got a new Crank sensor from terrybullwon (thanks James) and that cured the hot start problem (I hope)
The overboost problem was a faulty n75....although it was new from vagparts about 8 months ago.
Doug from MRC said it could have been affected by the HID light pack which was almost touching it in situ....?????????? changed it and no more overboost protection.
We also sprayed the MAF connection and it seems so much better. So a combination of all three mentioned above and it running like new....Should do as i have replaced pretty much everything on the car, Dougs jaw hit the floor when I showed him the list!
