Front wing removal, ASAP!
  • lind4hl
    • Jul 2008
    • 2465
    yep, as topic, i need to get my front wings off tomorrow, and i dont have a clue how to get the trim on the wing off,
    i have taken off all bolts except the 2 ones at the bottom where the trim sits on the fender, but how do i remove the trim? like the other door-trims etc where it slides on? cause it seems glued or something
    This trim:
    it looks like i dont need to remove the sideskirt to remove the bolts there, correct?
  • spink
    • 4382
    Yours probably has a load of sealant holding it on,take off the 2 plastic nuts and pull it off outwards
    • Foeglass
      • Apr 2009
      • 68
      mabey this helps? around the bottem of first post it shows you how to remove the trim fromt the wing.
      http://www.s2power.com/forum/viewtopic.php?f=4&t=4030
      "95 Audi S2 Coupé
      "02 Audi A8 6.0L W12 Quattro
      "01 Audi A8L 6.0L W12 Quattro
      "94 Audi Cabriolet 2.8 (in bits 'n pieces)
      • lind4hl
        • Jul 2008
        • 2465
        Spink, plastic nuts?
        foeglass, hm i might try that version, since i´m not going to use the trim anymore, they are for sure expensive though..
        • Foeglass
          • Apr 2009
          • 68
          you can see the plastic nuts here: http://www.s2power.com/forum/downloa...1979&mode=view
          "95 Audi S2 Coupé
          • lind4hl
            • Jul 2008
            • 2465
            tnx guys!
            • madpugger
              • Sep 2007
              • 1901
              Are you wanting to sell the old trims?
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
              • lind4hl
                • Jul 2008
                • 2465
                from the front fenders??
