The paintshop said that the Tailgate seal was not availible separetley, so the left the old seal out and put the rear window in without it as it was damaged on removal. Ther is a horrid gap, so I guess I have to buy a complete new tailgate seal and window now? Is this right? Audi say its a complete part only? Please help.
New Avant Tailgate Window Seal! RS2
Tags: None
I fitted a new glass a while a go. It came with the edging strip.The paintshop said that the Tailgate seal was not availible separetley, so the left the old seal out and put the rear window in without it as it was damaged on removal. Ther is a horrid gap, so I guess I have to buy a complete new tailgate seal and window now? Is this right? Audi say its a complete part only? Please help.
Don't know if its available separate...
Probly not know the sods!
Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8 -
So the tailgate came with the rubber seal, metal black edging, and black metal corner trims? I am going to order a complete new one if thats the case! Oh dam.....this respray is getting very expensive!Comment
The black metal trim strips and corner pieces are available separate from the glass. Below are you part numbers. You might need to add an "01C" suffix for the color code.
8A9 845 521 A left trim strip
8A9 845 522 A right trim strip
8A9 845 521 B upper trim strip
8A9 845 511 left upper corner piece
8A9 845 512 right upper corner piece
4A9 853 367 B lower middle piece
CheersComment
