as the title says, have done a search but can only find lhd details these are the ones from vagparts they`re for a rhd coupe both passenger and drivers side i thank you!!!!
aerowiper blade part numbers
Taken from another thread, I think this was originally posted on another forum by Jas (I assume Jas11n)
a little confusing, so here goes.
Longer blade = 1J2 955 426A (Passat)
Shorter blade = 1J2 955 425A (Lupo)
The part numbers are "6X2 998 405" but if you were to order this, you'd get the arm "and" the blade. You need two of these (arms).
In summary;
2 x lupo arms
1 x lupo blade
1 x passat blade
which boils down to,
6X2 998 405 x 2 (two lupo arms with blades)
1J2 955 426A x 1 (passat longer blade)
You'd then have one short lupo blade spare.
Daft that you can't order the arms on their own!!
(passat blade on drivers side)
HTHCheers'en, AndyC
cheers just wanted the "blades as i have the arms went to dealers this morning with the car, took them off took them in 25 mins later err sorry cant help you, do you know what car they`re off? if i knew that i`d have said
can these be purchased from gfs by any chance?ABY Cricket Green Pearl Coupe, blk leather
If you can measure the blade length and the position of the bracket in the middle I will work it out for you. They are more than likely a Passat blade and a Lupo blade.
You don't have to buy the Lupo blade and arm anymore. They now come as separate parts.
Benthe best intentions are fraught with disappointment - gil grissom
