Coupe door seal replacement - water leaks
This is a sticky topic.
  • Coupe door seal replacement - water leaks
    In an attempt to try and tidy up loose ends of various threads about mine and other folks Coupe water leaks - here is an attempt at a sticky thread to describe process of changing the door seal.
    By way of quick history - I was getting water ingress in the driver side footwell. Most of this was coming from a damaged grommet on the cable for the bonnet release that travels up UK drivers side rain tray - near the fusebox. I used some gutter sealant to effect a good repair on this. This stuff stays nice and flexible - it doesn't harden or set like a glue or silcone based stuff.
    However - that was not the full story.
    I was still getting water in at bottom of A-pillar. The attached pic is a mild example of where it appeared inside the car. Look just right of the left trim clip... you can see by the rust on the procon cable tube that a fair amount of water had been creeping in for a while.
    The carpet was salvagable but I had to throw out the underlay foam/fiber stuff.
    On further investigation the top part of the door seal at the A-pillar was not fitted tightly as a clamp clip had broken off. I replaced this along with the 'squishy' pad that fills the gap there. Still no joy.
    My attention was then turned to the windscreen and I used a lot of 'Captain Tolleys Creeping Crack Cure' to make sure it was watertight. But still no joy.
    Next I resorted to injecting some of that gutter sealant into the door seal as an attempt to tighten it up and prevent water ingress. This actually made things worse as I was soon getting water onto the drivers seat.
      Much time passed and my car interior was looking like a botulism factory with some wonderful fungal creations. I couldn't bring myself to photograph such a hideous sight so sorry about that... Fortunately for me it all washed off a treat with AG interior / fabric shampoo.
        I have put some pieces of tape at a 45deg angle to teh door seal to direct the flow of water away from the interior. This has worked well. I would also suggest adjusting the door seals and adding a bead of black sealant to them, parallel with the top face, to direct any water that gets past the top seal away from the door shut. I have done this with tape and again its' worked quite well. HTH
          I sourced a 2nd hand door seal - from a forum hero in Skye (name to be inserted when I can remember) - no cost to me which was fantastic. It sat in the garage for months but yesterday I finally got round to fitting it...
          Removal of the old one was easy enough though I paid some attention to the B-pillar and roof area to see just how it was located so snugly.
          When I had the old one off I had to remove the remnants of gutter sealant as the door seal needed to be fitted onto a dry/clean surface. I used POR15 solvent to quickly remove any old sealer. Do not get this on plastic though !
          Then I noticed that two rivets were broken/hanging out of doorway trim - one at the roof and one at the front screen. I fitted two new rivets of a good size - lucky.
          170 - half a dead rivet... no clue why this weakened so
          171 - new one installed towards top of windscreen
            172 - Note foam block at top left of doorway... this is where I started fitting the new seal. Its a bit fiddly to start with but once you get a little grip in the roof section it takes the weight enough that you can start to work into the corner and B-pillar
            176 - On the roof section I found that setting in the seal at the lower edge first then squeezing the upper section in with a plastic trim tool was a good method... something with a good sturdy thin edge - but not so sharp you risk cutting anything
              WIth the 'new' seal fitted it was time for the hosepipe test and it was almost perfect... still a trace of water getting in at top of A-pillar and making its way onto inner side of seal and into the cabin. This proves at least that I was initially on the right track.
              There is a couple of bits of trim on the actual door near the mirror that help form the seal to the upper part of doorpost - these look a bit worse for wear and really need to be renewed. However, I felt that reducing the gap between that and the door seal had to make an improvement.
              I carefully sliced out a section of the old door seal and inserted to the area where the door trim meets the doorpost. The seal peels back easily to accomodate this extra bit being slid in.
              179 and 181 show this pretty well... 181 shows just how far the water ingress gets - before the fix the water came further inboard on that seal and made its way inside.
              Now its all lovely and dry inside - pic 180 taken after 30 mins of full hose action
                Coupe door seal fix
                Congratulations Paul,
                What does the extra bit of seal look like and where does it go please? It's probably me being dense.
                Perhaps those of us without a spare seal could replicate it with some other rubber?
                Thanks,
                Nigel
                  /\ what he said
                  Mine is leaking in via the black triangle trim area on my drivers side
                    And from this day forth that this all too common fate shall be referred to as the "cursed black triangle of watery death". This common ill will be sure to strike fear in the hearts of every coupe owner across the land.
                      Good work Paul, i agree with Nuvo on this one, bound to be to the big problem for any coupe at some point in its life.
                      Group buy on door seals and rubber Triangles me thinks at the right price anyway
                        I've binned the old door seal (or is it still in a black bag ?????)
                        Anyway - I just cut out a section from the old one from section at top of door post - where it meets the triangle on the door. I just inserted by hand to give me an idea how far it would go then trimmed it carefully based on that.
                        You don't even need to sacrifice a door seal of course - cutting a section of say thin neoprene foam from an old wetsuit - or some of that black foam you an get as wooden floor underlay would be fine... its about 3mm thick maybe.
                        I will have to buy new triangle trims for the drivers door of course - but this seal shim is a quick n cheap fix for that area. I had other issues of course that I then made worse with sealant in the wrong places - strange but true.
                          Good work Paul...!
                          I suspect all us coupe owners will need new triangles...
                          Actually, on mine there are the rubber bits fitted on the door which are really in poor shape....
                          I will be out there again tomorrow, fiddling with my rubbers
                            I feel the door triangles are the root cause here, but a wedgie in the door seal works a charm.
                            • #15
                              I just fiddled with my black triangle and moved it 5mm or so. Now that the carpet is out I had the regulation coupe tidal feature in the passenger side foot well. Will do the driver's side some time soon. I am also missing rivets and had a few bits on the A pillar trims that weren't right. Bloody window fitters, do your job right!
                              When moving the triangle you can go too far and create a gap at the top of the window, I angle mine towards the car so that it has pressure on it and should seal better.
                              I've got a spare set of black triangles to fiddle with, I've come up with the idea of running a bead of black sealant down the top edge to create a positive seal rather than a flat seal that wicks water.
