rs2 crossmember help
  • valjo
    • 1110
    • Country: Latvia
    hi !
    i have problem fitting rs2 crossmember to my audi s2 aby. as i understand it should be play and plug, but i can not fit it. could somebody confirm that it is plug and play please ?
    furthermore i would like to ask if anyone could meassure distance between bolts on crossmeber, so i will be sure that my rs2 crossmember is not bent
    thanks for any help in advance
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
  • lind4hl
    • Jul 2008
    • 2465
    some cars have had this before, needed to push the framerails togheter (could have been crashed before etc.)
    measure mounting points between your holes in the framerails
      See here http://www.s2forum.com/forum/showpos...&postcount=187
      • valjo
        • 1110
        • Country: Latvia
        problem solved. rs2 crossmember fitted
        Audi Coupe S2 1993
        Audi V8 4.2 1993
        Audi cabrio 1998
