How to remove lower trims on the front wings
  • Jonnybravo
    • Aug 2008
    • 2051
    The lower body trims consist of 4 parts per side, I haev removed the door ones with ease and with a bit of a fiddle got the rears off as they were siliconed in but how do the ones on the front wings come off ?
    I know these are uber rare so obviously don't want to damage them when I remove them.
    Can't find a guide on how its done but I know people must of had them in the past.
    Thanks in advance
  • vader s2
    • Mar 2008
    • 141
    how to remove lower trims on the frout wings
    they are held on with a 8mm nut.
    cheers paul
    • Flat on my back
      • Jan 2007
      • 2449
      You'll need to remove the arch liner to gain access to the nut.
      Carlos.
      • Jonnybravo
        • Aug 2008
        • 2051
        Bingo ! Thanks guys !
        • Flat on my back
          • Jan 2007
          • 2449
          How easy did the doors ones come off?
          Carlos.
          • Jonnybravo
            • Aug 2008
            • 2051
            Very easily, I have another to do tomorrow so fingers crossed they come off as well !
            • Jonnybravo
              • Aug 2008
              • 2051
              Out of interest were we talking about the same trims ?
              The ones on the wings on both cars were fixed on with tape, no M8 nuts, nor were the wings drilled for them so looked factory how they had been done.
              • Flat on my back
                • Jan 2007
                • 2449
                I was on about the 'rubbing strips' not the door/sill trims.
                Carlos.
                • vader s2
                  • Mar 2008
                  • 141
                  thats odd. i resprayed my 91 3b two years ago. my front wings trims were held on by 8mm nuts. and looked factory also. how old is the car your working on ?
                  regards paul
                  • Jonnybravo
                    • Aug 2008
                    • 2051
                    The car is a 1992 and the other is a 1993 model Avant. I am referring to the rubber trim the plastic one thats part of the sideskirts.
                    • vader s2
                      • Mar 2008
                      • 141
                      ah i see. my mistake. sorry mate i understand now what you were on about.
                      • Jonnybravo
                        • Aug 2008
                        • 2051
                        I should of has "not" in there but I think you knew what I meant !
                        • Alistair E
                          • 479
                          Looking at replacing the lower trims and just want to confirm which ones are being talked about here. I know the door ones slide, but what about these? What holds them on?
                          • Jonnybravo
                            • Aug 2008
                            • 2051
                            If its a Coupe it would appear they are bolted on, the Avant ones are stuck on so just run a very thin sharp blade down the back of them to cut them off.
                            • Alistair E
                              • 479
                              It's an avant. Are both the fronts and rears stuck on?
