sunroof problem
  • sunroof problem
    Just curious if anyone has had the same problem as me before I tear off the headliner in attempt to see whats up with my sunroof. The drivers side rear corner of the sunroof when fully closed is sunk into the opening and not level to the roof. Some times it seats properly but then that one corner seems to sink down leaving the sunroof unleveled. It doesn’t leak but looks ridiculous.
    Is there something common that breaks, maybe a missing stop. I can’t find a diagram parts in the sunroof so I have no idea whats wrong.
    Also is there anyone making a rubber sunroof seal to replace the deteriorated felt one?
    Any part numbers or web links would be greatly appreciated.
    It’s a 1995 b4 90
    Ask the guys at QuattroWorld Forum for 80/90/CQ. They can help you.
      if its anything like the coupe one you can adjust how the sunroof panel sits - remove the heading trim panel off the sunroof and there are 4 pozi-drive screws, one at each corner - loosen them off and you can adjust how the sunroof sits. HTH
