lacquer peel - temporary repair?
  • lacquer peel - temporary repair?
    I was intending to get the roof resprayed and the glass changed but i have run out of time...the lacquer is peeling on the top of the a pillar, is there a quick way to clean it up and make it look reasonable....its irks me that the paint is exposed and is letting the rest of the car down
    thought was to just get some lacquer from halfrauds and just try and seal it but i figured it would look a bit messy.....any tips etc?
    Ta
    David
    1992 3b S2 Coupe
    David, its a respray of the whole panel / affected area I am afraid. You could try adding lacquer but I think it will do more harm (in terms of appearance) than good. I would not worry about the paint being exposed if it is just lacquer that has peeled. If it is down the metal then there is more to worry about. The lacquer is more of a decorative layer than anything.
    HTH
    Cheers,
    Steve.
    The Perfectionist
      Keep it topped up with a decent sealant/LSP until you can get it sorted properly
        How many days you got?
        Get it up to aiden, mine's having the roof done over the next couple of days
          i will get it up to him when i get back for sure but not really enough time to now i dont think
          1992 3b S2 Coupe
            If you get a chance have a word with him and see what he can do
              Ta
              David
              I had the same problem with my Polo last October and like you wanted something to stop it getting worse over the winter. I bol**ked on lots of Screwfix clear metal lacquer and to my surprise it's still on looking good - not up to Steve's standards but it has stopped the paint underneath getting worse.
              John
                hmm interesting, might give it a go just to protect it a bit thanks
                1992 3b S2 Coupe
                  wet sand the surrounding area and the exposed paint lightly then blow over with laquer ,flat off again then machine polish back to gloss
                    Easier said than done. (Just ask Sonic )
                    He broke through the clear coat and managed to get down to the undercoat on my wife's Audi 80 sport trying wetsanding! wave:
                    I would not recommend wetsanding to anyone but a Pro or very very keen amateur. Although if you are going to have a respray eventually what have you got to lose?
                    Cheers,
                    Steve.
                    The Perfectionist
                      Keep it simple and just let a pro do it. Often trying to cover it with rubbish will only make it more if a job when the professional comes to re-finish it
                        Cheers,
                        Steve.
                        (apologies again, 2 years later)
                        It was literally like putting a molten knife through butter, one wipe and it was gone!
                        Taught me alot...
                        S2Forum.com Administrator
                          Still
                          The Perfectionist
                            Christ you boys love that blue tape!
                            • #15
                              Saves alot of hassle clearing up the dust in tiny gaps and polishing anywhere near rubber.
