Righto i finally tracked down an audi 90 reflective rear panel to fit to my 80 avant.
Looked into swapping it and could obviously see that the handle to pull the tailgate had to be chopped down a fair bit, which i have done.
Fitted the rear panel and the lock again but i struggled to get the tailgate to re-open, had a look inside and adjusted the rods to the latches to suit but however i set them i cant seem to release the tailgate, or if i do adjust them so i can i cant lock it then!
Sounds like a really simple mod, which it is in effect but i just wondered if anyone else had the same problem?
Any guidance if i am missing something would be great, or if anyone has done a guide to doing this with photo's would be great?
