Help and advice on RS2 Trim Please
  • ian4455
    • Nov 2010
    • 787
    Is there something missing at the bottom of the door post gap?
    How is the rear tail gate trim removed?
    How Can this badly oxidised black section be repaired?
  • DeanG
    • Nov 2007
    • 468
    Door post gap
    The bottom of my door post looks exactly the same.
    • david
      • Oct 2008
      • 1268
      i 've asked my self thesame question many times and i think not.
      that's how they comeout the factory,with a great big gap i'm afraid.
      [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
      RS2 VOLCANO BLACK] soon to be broken to bits
      • Simoni
        • 215
        • Country: Belgium
        That is indeed how they come out the factory!
        • ian4455
          • Nov 2010
          • 787
          Thanks, anyone know how to tackle the corrosion on the black strip on the last picture. Window is getting removed to sort the paintwork out, just not sure if this part is available from dealer ??
          • Al Wyn
            • Nov 2006
            • 3746
            iirc they are a standard 80 part so would have thought so...failing that im sure there will be good second hand ones out there at breakers
            S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
            • ian4455
              • Nov 2010
              • 787
              Part number for this ??
              What is this part called and anyone know part number ?
              • rs2315
                • Jun 2006
                • 867
                Just took a look at mine.
                The corroded part looks like a cover thats riveted to the c pillar.
                I've been on Etka and it gives a p/n 8A9 809 239 A for left c pillar but that looks like the whole pillar, and not the riveted strip
                Hope someone can shed some more light on if this strip has a seperate p/n.
                rs2315.
                  A80Q/RS2 B, C and D pillar trims
                  8A9 809 239 A is the PN structural "C" pillar structural component, not the external trim. The trim is something like these I found:
                  B pillar:
                  C pillar
                  C-pillar
                  D-pillar
                  D pillar
                  For replacements, I would start with a dealer.
                  • rs2315
                    • Jun 2006
                    • 867
                    Thanks urs4boy,
                    Found it on Etka, at last
                    Cover for left C pillar 8A9 853 377 B
                    Pop rivet N 016 199 2
                    rs2315.
                      Originally posted by rs2315
                      Thanks urs4boy,
                      Found it on Etka, at last Cover for left C pillar 8A9 853 377 B
                      Pop rivet N 016 199 2 /rs2315.
                      Good news. *IF* I had looked a bit better, I would have highlighted the C pillar trim so you could have seen the PN. Likewise the small D-pillar trim, which can only be found under A80 (not Q) (nothing in A80Q or RS2 - go figure):
                      C-pillar
                      D-pillar
