How to remove boggo bumper?
  • Max M4X WW
    • Nov 2010
    • 226
    Hi all,
    Sorry to ask this question but I'm not having much luck with the search function! My mechanic is going to change my water pump etc and would rather I took my bumper off before doing the work. How do you remove it?
    The bumper in question is above!
    Thanks, Max
    1995 Audi 80 Avant 1.9 TDi
    1995 Fiesta Zetec Turbo Project
    1998 Mazda MX-5 1.8 'RS'
  • Skull
    • 3506
    • Country: Slovenia
    far left and right grille pull out, imbus screw up there behind the black plastic trim (use a torch, u will spott it), undo bolts at arch, pull the side of the bumper out, first on top (press down and towards you), than the bottom, press down and towards you.
    dont hesitate to use brute force.
    Audi Quattro WR
    • irishs2
      • Apr 2009
      • 2455
      Does this help?
      Eric
      95 S2 Avant under rebuild.
      • sam80quattro
        • Oct 2006
        • 1496
        yup allen bolts pointing upwards when you remove grills
        • Max M4X WW
          • Nov 2010
          • 226
          Ok great! Does #17 hold the brackets on?
            Max,
            The area to look at is 2, 24, and 26, which holds the bumper on at each side of the front of the bumper.
            The # 17 you mention is one of three screws that holds on the black plastic bracket at the side of both wings, the bumper's built in brackets on either side "slide" onto/off these black plastic brackets, (one on either side of the car), once you see it off it be a clear as day, but right now, hope my post helps somewhat.
            Someone should have one or two helpful photos ?
            Kind regards.
