Has anybody done this before? I have problems with fitting. Sides of the bumber comes too out from the body. I have OEM typ89 brackets. Anyone know tips? Should I change brackets or make brackets by myself?
It should go on fine, the s2 rear bumper is the same as type 89 one's. Once you've fitted/slid on the new bumper screws inside the rear wheel arch help pull in the sides.
the rear arches are much wider on b4's than they are on b3 saloon, i don't know anyone that has successfully done the swap... maybe someone will be along to prove me wrong
