s2 gastank VS. rs2 tank
  • RIX
    • Jul 2004
    • 229
    • Country: Denmark
    i just want to now if the rs2 tank is bigger then mine (s2 avant(61 liter)),cause i am feed up with it being smaller then the coupe(70 liters),i would like to driver more the 350-400km on a tank full(55-58),i have seen and mtm tank 80liter´s in the wanted adds i germany,but if the rs2 tank 70liter ill be happy with that.
    Thanks in advance
    RIX
  • Mihnea
    • 1288
    Rix, I'm pretty much afraid it's the same tank...
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • Pete_RS2
      • 800
      Yep RS2 is only 61 litres too.
      Now RS2'less
      '99 VW Passat VR5 Sport
      • RIX
        • Jul 2004
        • 229
        • Country: Denmark
        crap but thanks for the info,but does anybody now where i can get on of these mtm tank or can i fitt one from a coupe.
        RIX
        • Vagsport
          • 533
          You can build in a 15L tank to your Avant, which will feed your main tank as the level drops. Coupe tank will not fit. You need to access how much room you have in the Avant rear quarters...
          Siena
