Headlight washer jets
    Ive been having a problem with mine for a while, whenever i use them it just seems to foam up and spray a load of it over the lights and the bonnet before you get a bit of a jet on the head lights.
    Any idea what the problem is? or anyone had a similar problem?
    Should there be a one way valve in the pipe to stop the water running back to the tank?
  • Fat Audi 80
    • 10547
    Can you disconnect them? I hate getting a car covered in screen wash every time I wash the windcreen
    The Perfectionist
      It has crossed my mind several times, 'when' i get my RS2 bumper will probably do away with them.
      Would like to get them sorted if i can though
      • blu_s2
        • 392
        I looked at this when I had the bumper off at the weekend... I didn't notice a one way valve and I doubt one is needed as the pump is at the bottom of the tank.
        Jim
        • dan_b
          • Sep 2003
          • 3670
          Blocked nozzles? Is the black nozzle piece actually still there? They're only held in by an interference fit so they can work themselves loose and blow out under the jet pressure!
          Happily, you can replace the nozzle inserts from VAG Parts for about a fiver, not the £125 that a stealer quoted me for the entire unit...
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Just rewire them and aim them at your IC!
            SS
            • dan_b
              • Sep 2003
              • 3670
              LOL!
              Doug's got an IC spray kit, wonder if he's actually got it installed yet...
                nah dont think he has yet, ive been thinking that with the IC too, I'd look a bit stupid driving down the 1/4mile with the washer jets going for most of it! LOL.
                Might try changing the inserts, they both have them in at the min.
                • APNess
                  • 479
                  I've been meaning to get off my *** for a while with the i/c spray. Some bits from halfords - pump, spray nozzles, plastic pipe, some electrical wire and a live feed, a t piece, some garden hose, and a clicky thing from Maplins with a current going through it and a magnet to attach to the throttle wire. Mount on inside of front bumper poiting to i/c and Hey presto - i/c spray for WOT operation, AND you get a level indicator to tell you when empty (cause you have no squirty left either.)
                  Oh yeah, don't put screen wash in either except at winter (and you can disconnect it then anyway cause it's cold)
                  I'm a jeenius. Geenyuz. Geekneeus. Ge... Ah fook it I'm an idjiot.
                  Still, it's on my list o things to bodge....
                  Paul
                  'The Bacofoil Express'...
                  No more.
                  Leon TDI 150 run in now.
                  Very slow.
                  Needs a chip.
                  • Doug_RS2
                    • 3847
                    My mister is still not fitted - I think I will have it fitted for the RR though
                    • audiman
                      • 4827
                      ******** will you, its been on the 'to do' list for ages now!!
                      Tom C - www.rcmr.co.uk
                      Audi UR Quattro
                      Audi 100 C3 2.0 5 cyl 115ps
                      Audi B5 RS4 645ps 911nm
                      • Doug_RS2
                        • 3847
                        It will be done - are you plumbing your garden hose back in for the RR?
                        Have you cut the number plate hole yet?
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          AFAIK, they only spray when the headlights are on. Turn off your lights when you spray the screen!
                          Don't have an accident tho'
                          David
                          • Fat Audi 80
                            • 10547
                            David
                            I know! Bit of a pain in the **** when dark though. I am one of those that likes side lights in the daytime too....
                            Oh well.
                            Cheers,
                            Steve.
                            The Perfectionist
                            • Stick Insect
                              • Dec 2003
                              • 2338
                              Oh well.
                              Cheers,
                              Steve.
                              Point the jets to the side and use them when passing traffic wardens
                              Result!!
                              David
