Hydraulic pump for softtop problems
  • quattrostyle
    • Oct 2006
    • 6229
    When I bought my cabriolet a few years ago there was an issue with the pump for the softtop. It was leaking a bit, so after a refill I could open and close the top a few times untill the fluid level was too low again.
    Now I've bought a pump from a forum member over here and installed it, but although it doesn't leak it also won't open the top
    The original pump at least tried to open it, but this one does nothing at all besides getting hot.
    Below is a picture of the not working pump, the front 6 upright pieces (what would they be called) became very hot when operating the switch inside the car, the rear 2 stayed cold.
    Anyone got a clue what could be the cause?
  • quattrostyle
    • Oct 2006
    • 6229
    Could it be air in the system because of the pump change?
    • quattrostyle
      • Oct 2006
      • 6229
      Well summer is over but I found the problem finally...
      There is a small magnet inside the reservoir that blocked the pump's oil intake. So used a tie-wrap to fix it properly so it can't block the pipes anymore. After that I mounted the pump again and tested it about 5 times, maybe more. Everyhting looked fine so I put all the trunk carpets and trim back on to have a cruise in the sun.
      ...Well as always that was not how it went. Gave the car a quick wash and went to pick up my girlfriend to drive down some nice roads. But hey ho the godd*mn top wouldn't open again to say I was pissed off is an understatement.
      A week later I took the carpets out the trunk again and it worked immediately, there must have been a faulty connection somewhere then
      One picture is how it should be mounted and the other how it was when I took the reservoir off. The magnet must have become loose during shipping from the UK to me I guess.
      • quattrostyle
        • Oct 2006
        • 6229
        And here it is as it went back into the lock up till next summer, don't think I did more than 1000 km's in it this year
        • DickyP
          • Mar 2008
          • 79
          Very nice indeed and you have done more miles than I have this year!!
          • quattrostyle
            • Oct 2006
            • 6229
            In what car?
            Luckily I still got my type 81 80 TD and type 85 CQ to drive
            The cabriolet accompanies my 90 quattro type 85 now
