Coupe B Pillar carbon trim
  • Monkeymagic
    • Mar 2012
    • 3419
    I have noticed that the black trims on the exterior b pillars on my coupe are a little scabby at the bottom. I was thinking of the carbon trim one.
    What are peoples views on these, where from and do they fit by rivets as per the originals? any comments appreciated. Steven
  • TimE-J
    • Jul 2009
    • 1292
    Your probably best off contacting aronmatic2 here on the forum, I'm sure he makes them for the coupe and avant!
    96 S2 aby Coupe. Rebuild Project
    96 mk3 golf tdi daily.
    • Monkeymagic
      • Mar 2012
      • 3419
      Cheers Thanks i'll pm him. Any one fitted them? they look a vary good fit on pics I have seen. My other option is to have mine stripped and powder coated but think the carbon on a black car would look the nuts.
      • Monkeymagic
        • Mar 2012
        • 3419
        I think i'll be getting pair of carbon trims soon. DOes antone know if you remove the old ones to fit these carbon ones. I presume you have to.
        Is removing the old ones just a few rivets?
        Also are the rear side windows removeable on the coupe?
        I have a small amount of lacquer peel and would like it sorted properly rather than quick blow over.
          Yes the rear quarter windows are pretty easy to remove & you need to remove the B-pillar trim to do that anyway
          • Monkeymagic
            • Mar 2012
            • 3419
            that was my thoughts. going to have screen out to address little scab on top edge so Will get all paint done at same time
