Taking apart rear pop out windows from a coupe..
  • s4kido
    • Aug 2009
    • 251
    • Home: Poland Current: United States
    I have a question.. i brought a set of rear windows from a member and was shipped to USA.. it was well packed and all and glass didnt shatter.. but the little rod that is mounted to the glass and get connected to the motor broke.. wanted to know if anyone know how i could take this one off and if i could get a replacement rod?? if i cant get one i will need to make one.. any help would be great..
  • LHD_Kid
    • May 2006
    • 3696
    It is easy to remove, the button on the outside is basically the nut. It unscrews.
    Really, it should have been unscrewed and removed when shipped....
    • s4kido
      • Aug 2009
      • 251
      thank you
      i see the inside has some sort of a special tool need with like 3 pins???
      can i buy the rod??
      • AudiCoupeParts
        • Feb 2007
        • 347
        rod
        Hi. Part number for the rod from ETKA. 895847115A cost over 86 euros! Well over $100 US.
        • LHD_Kid
          • May 2006
          • 3696
          Yes, that's true, but you will probably find it's not very tight and you are likely able to undo it just with your fingers.
          I think there's a plastic washer there too...
          Chris
