I had this idea for a while. But I refused to take apart my freshly painted coupe quattro. Since I bought another car it's all game. Anything goes and I will try many things to find the "look" and the "solutions" I want to put this coupe on the road. I am not the biggest fan of the stupid rubber/plastic trim.
With a bit of work and some fiberglassing or bondo.. I might be a happy camper.
Josh
Just call me the MAD Scientist.
Josh that's a cool idea! I myself do not like the rubber mouldings on our cars either however have you given thought to trying RS2 lower mouldings as an option to test? good luck
Well the whole pt to using these molding strips is because It's a cheap option. I would cut and work them to fit and then have fiber glass copies made if there was enough interest.
I am not the biggest fan of getting parts from europe anymore. On a limited basis I will, but not alot.
Josh
Well sounds like an interesting project... I'll keep track of your progress, unless I find some used rs2 lower trims and do some hacking myself. Are the Brocks still for sale? If they're still available mid-next year I will buzz ya!
Josh
I like the idea but wonder if the rubber 'seals' have any other use than to stop water ' blowing' into the car when at speed. A better option is needed. Good luck with your project.
I am going to pull the fenders or make new ones on this coupe to use them.
Josh
David
I am confused what are you talking about david?
Thanks
Josh
